Stitch Groove Weld
Stitch Groove Weld
MGarthMadden
Observer Observer
Stitch Groove Weld
MGarthMadden
Observer
Observer
I have a weldment that there is a weld prep and I am trying to do a groove weld to fill it. However, I want that groove weld to be in stich pattern. Is there a way to do a stitch pattern for the groove weld?
The first picture is what it comes out to be doing a groove weld. The second picture is a improvised fillet weld to try and show what I want it to be.
Groove WeldGroove WeldImprovised Fillet WeldImprovised Fillet Weld
johnsonshiue
Hi! I don't believe Groove Weld has such behavior. Groove Weld is more like "Loft", going from one arbitrary face to another arbitrary face. There is no intermittent spacing.
Many thanks!
Software Test Engineer
3D4Play
You can just put the correct weld information in the weld symbol, which is what the welder is going to look at no matter what your 3D weldment looks like. Worst case, they will ask why you have a continuous weld shown pictorially, with a groove weld symbol called out as a stitch. Then you can say, “yeah, Inventor doesn’t let me model a groove weld with a stitch, so I put the correct symbol on an incorrect model representation.”
Gabriel_Watson
As @3D4Play above said, sometimes you can just add "Cosmetic Welds" which have no geometrical representation, and still get the full note imported into the drawing.
MGarthMadden
Observer
Observer
Thank you for the answers I am somewhat of a perfectionist sometimes so I thought that I would ask even thought I didn't think that there was a way to do it.
