STEP FILE WITH MULTIPLE PARTS
WILLIAMF
WILLIAMF
A customer sent me a single step file with multiple parts (15) separate parts that need to have separate detail drawings made.
Is there a way to pull out the separate part so I have 15 separate parts?
I attached a pic so its easier to visualize what I want to do.
Dell Precision 5820
Windows 10Pro
Quad Core Intel Xeon
32 Gb SDRam
NVIDIA Quadro
Product Design Suite 2019 Ultimate
On the Manage tab select Make Components. Select the solid bodies to create separate parts files.
WILLIAMF
Great, worked perfectly
Thanks a lot!!
Dell Precision 5820
Windows 10Pro
32 Gb SDRam
NVIDIA Quadro
inchul.lee
Autodesk Support
Autodesk Support
Hi WILLIAMF,
It looks like you 1) imported a STEP file in an Inventor part environment or 2) opened a multi-body STEP file. So, bobfournier4926's solution works perfectly.
If it's a STEP assembly file, you can also simply open the STEP file directly. It will be automatically opened in an Inventor assembly environment with all the individual parts.
Inchul Lee
