STEP file import to Inventor 2021 comes blank
Message 1 of 10
Hello Everyone,
I have a structural 3D file from STAAD Pro and want to open in Inventor 2021, the STEP file I received from our structural engineer opens as blank in inventor, I searched the entire forum and lots of people talk about software or hardware issues, I am sure in my case both software and hardware are ok because I used 3 platforms with 3 different inventors from 2019 to 2021 and still the same issue, can some one help please? I have attached the file
Thank you
Replies (9)
Message 2 of 10
imajar
Same here, nothing imported in Inventor, Fusion, or 3DS.  But I did get something in NavisWorks.  Unfortunately, the only thing Navisworks will export is .fbx, it is attached below (as well as a .obj which inventor can open).  If possible, I would suggest you read the STAAD Pro documentation and see if there are any export options they can change and request a new export.  Inventor can open mesh files, but it isn't awesome.  (I might suggest opening the fbx in fusion and using that convert to solids if you cant get a better export).
Aaron Jarrett, PE
Inventor 2019 | i7-6700K 64GB NVidia M4000
LinkedIn
Life is Good.
Message 3 of 10
JDMather
@Anonymous wrote:
I have a structural 3D file from STAAD Pro...
Does that software offer the option to export the STEP in Application Protocol Schema 203, 214 or 242 rather than as LPM6?
Message 4 of 10
ok thanks for the reply, it is definitely a software issue from STAAD.Pro
Message 5 of 10
Hi, thanks for the reply, no it does not give you those options, STAAD.Pro export beams as a line, i was able to open the DXF file in CAD, then from CAD exported to STEP file and then opened in Inventor, it worked, However I only can see the plates and no ibeam,
Message 6 of 10
imajar
Did you try downloading the file I provided in the 2nd post?  Did it not work?
Aaron Jarrett, PE
LinkedIn
Life is Good.
Message 7 of 10
Hi, yes I did, I can see the entire structure now, I opened the OBJ file in Inventor and it looks good, so without Navis this wouldn't be possible, but I really appreciate your help and followup on this,
Regards
Ari
Message 8 of 10
johnsonshiue
Hi! The STEP file is using a schema Inventor does not support. Another simple solution is to export it as dwg. Then Inventor can easily import it as 3D solids.
Many thanks!
Software Test Engineer
Message 9 of 10
U2097205
Community Visitor
Community Visitor
can you tell me how you transformed it into obj file ?
Message 10 of 10
imajar
Sadly, that was a long time ago and I don't remember exactly what I did. . . but if I were to try again, I would try to import the Navisworks generated FBX into one of the following and export out again as an obj.  (If you attempt fusion360, then you might attempt re-importing the source file and see how it goes).
  • Autocad 2018 or earlier (2019 and on removed the ability to import FBX)
  • Fusion 360
  • 3DS max
  • Meshmixer
And I don't recall if this was mentioned this previously, but the Navisworks method does not maintain geometry fidelity because Navisworks re-meshes on import - so if you need "exact" geometry, a different method would be advised (but I understand that sometimes you are simply stuck with whatever file you are provided!).
Aaron Jarrett, PE
LinkedIn
Life is Good.
