Inventor Forum
Step file conversion problems:
3 REPLIES 3
blair
331 Views, 3 Replies
Could someone from Autodesk look at a step file I have. Problems on the importing of file. I can e-mail the zip'd file, but will require a ftp site to download the file after importation and conversion to Inventor file.
The file is to large to post here.
thanks,
you can also e-mail me at: blair dot stunder @ arcticmfg dot com  (you can eliminate the spaces and change the dot to .)
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
3 REPLIES 3
wilkhui
in reply to: blair
Hi Blair,
What are the problems that you're experiencing?
If you want to try to email me the part I can have a look, inderjeet [dot] wilkhu [at] autodesk [dot] com
Indy
Inderjeet Singh Wilkhu
Product Owner - ASM
Autodesk, Inc.
blair
in reply to: blair
It should be comming through as multi-part assembly. I am getting alot of surfaces that require repairing. The supplier says that I am the only one having problems with the model/file. I will send you a zipped copy to test at your end.
thanks,
Blair
Delta Tau Chi ΔΤΧ
wilkhui
in reply to: blair
Hi Blair,
Just to summarise our email conversation - it looks like this is a case of bad input data i.e. the STEP file itself is the issue.
Please feel free to get in touch about anything else,
Indy
Product Owner - ASM
Autodesk, Inc.
