@richard.grundy
@richard.grundy wrote:
So that suggests the export of materials as RGB per solid part, but if I understand correctly there is no way to get materials to export (even as RGB) when assigned at sub solid part level e.g. assigned to a specific surface?
That would be correct. Basically because each CAD program has it's inner programming that is not easily translated.
Step files, IGES files and parasolids and such are universal translators for each CAD program.
All I really need is to end up with are poly selections for each material on the models once that have been tessalated, seems like I'm going to have to continue making poly sections manually in the DCC for now. (& yet we can put a person on the moon ;-))
Yet, when we placed a man on the moon, CAD wasn't around, so we have come a long way. Maybe by the time your grandchildren are using this software this will happen. 😋 😉
Not that this will help, but Inventor files will call up directly into Solidworks. So, if you setup your appearances within Solidworks like you have in Inventor, they can be applied rather easily.
Windows 10 x64 -16GB Ram
Intel i7-6700 @ 3.41ghz
nVidia GTS 250 - 1 GB
Inventor Pro 2021
Best Regards,
Scott McFadden
(Colossians 3:23-25)
