Hi All,
First time using Inventor...(Inventor Professional 2021).
I'm trying to create an external staircase that I can use within Infraworks (2021)
I need it to be sizable based on the overall height of stairs required, i.e;
- The width of each stair should be static at 0.225m
- The height and number of stairs should automatically resize based on the overall height of the staircase required
- The height of the stairs should be around 0.17m
The parametric lines and dimensions seem to change OK but the number of steps does not change.
I've attached the model.
Any ideas?
Thanks in advance!
Link copied
