Staircase not resizing
M_c3d
M_c3d
Hi All,
First time using Inventor...(Inventor Professional 2021).
I'm trying to create an external staircase that I can use within Infraworks (2021)
I need it to be sizable based on the overall height of stairs required, i.e;
  • The width of each stair should be static at 0.225m
  • The height and number of stairs should automatically resize based on the overall height of the staircase required
  • The height of the stairs should be around 0.17m
The parametric lines and dimensions seem to change OK but the number of steps does not change.
I've attached the model.
Any ideas?
Thanks in advance!
IgorMir
Have a read through this thread. https://forums.autodesk.com/t5/inventor-forum/what-is-the-best-way-to-create-place-stanchions-and-ha...
Cheers,
Igor.
Web: www.meqc.com.au
mikejones
Hi
It's working fine on 2021. Just a quick question for you since you say you're new to Inventor. When you drag the sketch to resize the stairs are you clicking on the update button at the top of the screen to refresh the changes?
Mike
Autodesk Certified Professional
M_c3d
@mikejones thanks that's it working now!
