Spur Gear Component generator - teeth collision issues
d.cample
d.cample
Iv'e got a 3D printing project on the go and I need to design a gear assembly. I'm relatively new to inventor but have used autocad for over 30 years. I have generated 2 gears using the spur gear component generator (see first image). all seems good, but when i look closely the teeth from one gear appear to be fouling the teeth from the second one (see second image).  I have attached the parameters from the generator dialogue box (see third image). I spent all evening yesterday trying all sorts of parameter combinations but while some work better than others I can't avoid some degree of tooth collision. For what I am doing and the tolerances on the 3D printer it probably wont matter too much, but for me that is not the point. The point is I'd like to know how to get it spot on. I even thought at one point it might be a screen display issue, but I exported it to autocad and was able to put a dimension to it. Any help to point me in the right direction would be greatly appreciated. Thank you.
mikejones
The tooth profiles generated by the spur gear accelerator are only a visual representation and not a true involute curve tooth profile, unfortunately. However, you can extract the correct tooth profile as a sketch once you've created the spur gears by RMB clicking on the spur gear in the browser and choosing Export tooth profile. In the subsequent dialogue you can alter the tolerance values etc for the profile and choose whether it's the pinion or gear that you want; you'll have to do it two times to get both, I don't understand why you can't just export both at the same time. What you'll get is a new part file with a sketch that is the correct profile. You'll have to extrude cut it and do a circular pattern to recreate the gear.
Long-winded approach I know and not very productive considering the availability of 3D printers in the workspace / homespace nowadays.
Come on Autodesk, make this an option in the initial gear generator window to create precise or simplified gears, let us make the decision whether to take the performance hit or not; with the power of todays computers, I doubt there would be any noticeable tradeoff.
https://forums.autodesk.com/t5/inventor-ideas/design-accelerator-spur-gear-tooth-profile/idi-p/64521...
Hope that helps
Mike
Autodesk Certified Professional
d.cample
Thank you so much for taking the time to reply, Mike. It makes perfect sense now, the way you explain it.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
