Spring Animation with Inventor. Can I visually simulate the compression/release of a spring?
cronosian96
cronosian96
I am brand new to 3D modeling and design. I am trying to place a spring within a cylinder. It always mates askew from the center point. But due to the request of the project manager. I need to animate the assembly.  Can I create a spring that I can visually simulate its movement within the assembly?
bwatson1967
JDMather
Can you Attach your assembly here (or at least the spring)?
There is an easier technique using Animate Parameter.
bwatson1967
JD I watched your video on creating the spring do you have one that shows how to animate it. You have peaked my interest as this looks to be much easier than I have been doing.
bwatson1967
And can that be done in an assembly
JDMather
You did not Attach your assembly here?
See at 22 minutes https://youtu.be/R_4-3k8wZh0
cronosian96
