I'm looking for a bit of advice on the best way to model these kind of parts.
As you can see, you can't flat pattern the part because of the obvious overlapping flanges.
Due to the main profile (Sketch 1) being either folded up or down means this is usually going to happen.
I'd like to split the part across the fold & create 2 solids which can then be unfolded correctly.
My problem is how to best cut out the fold so the flat pattern is clean with no errors.
I didn't manage to do this with either the split or cut command.
I've also tried unsuccessfully to create 2 solids from the beginning because there is a 5deg difference.
I've included 2 files
The profile & the actual part.
The profile should follow the entire part
Imagine instead of the fold the part would be welded at 5deg instead.
Hope this makes sense.
