Message 1 of 9
Split tool Lofted Flange
05:27 PM
Hi All,
I have a tricky modelling task that I need some help with...
I've created a multi-body sheet metal part with a lofted flange for a square to round transition (see attached file)
I'm using the Split command and a user plane as the split tool to make the lofted flange from two pieces along the shortest bend line (see Transition Split Plane feature in model).
The model is parametric with two key parameters OUTLET_DIA and FLANGE_ANGLE. The problem occurs when I change, for example OUTLET_DIA from 150mm to 200mm, the user plane loses all its inputs. I need to be able to change the key parameters without having to intervene and fix the plane each time. Any ideas how I can achieve this?
