06:02 AM
Good day sirs and madams.
I need to split a surface into different surfaces based on a sketch containing several squares. This is necessary in order to assign different material properties to each 'square' later in Nastran for analysis.
I have projected a 2D sketch onto a surface, however, it doesn't seem possible to select the sketch from within the split tool.
A possible solution may be to use the patch tool and create a patch from every square, however, this seems unreasonably cumbersome.
Is there a way to achieve this?
Julian
Split surface into these segments
