spiral bevel gears
spiral bevel gears
Hello, I am having trouble finding a solution to a bevel gear design accelerator issue.  I created a spiral bevel gear set with a 30 degree helix.  In the assembly they are shown with the correct spiral (pinion LH).  However, when I open the part (and consequently the drawing), it shows the spiral going in the opposite direction (pinion RH).  Does anyone know what might be the cause of this and how to fix it?  I have attached a screen shot of the assembly, part and design accelerator views.
Thanks.
martin.jacko
It looks like a interesting defect.
I see that it is simple dataset, could you please provide it ?
Martin
Attached are the part models and assembly.
xianhua.chen
Have you changed the Helix Direction after you modified 16012203-P2.ipt? It might have some problem when you want to keep the modification on the sub part, then you modified the top level.
Xianhua
Xianhua Chen
PDMS Quality Assurance Team
Autodesk, Inc.
Type a product name
