Sphere assembly
Sphere assembly
Message 1 of 12
Sphere assembly
Hi everyone,
How can I achieve this kind of sphere assembly? I've attached the image, thanks!
Replies (11)
Message 2 of 12
JDMather
@Anonymous wrote:
... I've attached the image, thanks!
Zip and attach Inventor file and that will tell me what version of Inventor you are using.
Message 3 of 12
WHolzwarth
Jeffrey, in another topic 2020 has been used.
Walter Holzwarth
Message 4 of 12
Thanks but I can't assemble them individually because the exercise says this
Message 5 of 12
JDMather
That is even easier.
Component Pattern.
Zip and Attach your attempt at the assembly here.
Message 6 of 12
Tried but wasn't successful
Message 7 of 12
WHolzwarth
IAM is not enough. Besides, I couldn't decrypt the picture.
Here's a multibody version (2020 IPT in Zip)
Walter Holzwarth
Message 8 of 12
WHolzwarth
And there's some stuff for development.
The magenta colored balls in the last feature (Polar pattern2) don't match their theoretical positions.
Polar pattern issue.jpg last feature don't match their theoretical positions.
Walter Holzwarth
Message 9 of 12
Thanks WH
Message 10 of 12
johnsonshiue
Hi Walter,
Do you mind sharing the files with me? I would like to understand the behavior better.
Many thanks!
Software Test Engineer
Message 11 of 12
I've finally assembled the ball pyramid, thanks wh!
Message 12 of 12
Hello there!
I see that you loaded the file, thanks it helped a lot. But I just wondered if there is anything that can make working step more clear to me? It is hard to know what to do first.
Thanks!
