Specifying opened window size (registry?)
Message 1 of 13
Like many others, I have a multiple monitor setup.
I was wondering if there is a way, possibly in the registry, to specify the size of the window that opens whenever I open a file or start a new one.
Right away, the window always seems to default to maximized, but if I could specify a number of pixels, that would be awesome.
Replies (12)
Message 2 of 13
DRoam
Do you mean you open a file from Windows Explorer and a new instance of Inventor opens, and you want to control the size of that window?
Or, you have Inventor running, and open a file from within Inventor, and want to control the size of the sub-window the file opens in?
Message 3 of 13
This one. 🙂
Message 4 of 13
DRoam
Gotcha 🙂 it would be nice if there were a way to do this. Personally I've found working with those sub-windows as anything but maximized to be very tricky and unpredictable.
I too would like more control over my window arrangement, particularly when it comes to multiple monitors. That's why I created this idea in the IdeaStation requesting the ability to have multiple full windows open 🙂
But if someone knows of a way to control the sub-window opening location and size via the registry, that would be a very imperfect but useful workaround in the meantime.
Message 5 of 13
I tend to have the windows 8 calculator docked on my screen at all times, and I don't want the new window maximized across two screens because the middle portion of the window spans two flat panel frames which is a completely useless deadzone to me. It is seriously impractical.
Message 6 of 13
Mark.Lancaster
I know the location is stored here: Hkey_Current_User\Software\Autodesk\Inventor\RegistryVersion<  >\System\Preferences\Dialog\ in the registry.  But you need a registry comparison software to determine which entry belongs to what dialog.
For example: "dm2d7b" belongs to the extrude dialog...
Mark Lancaster
Message 7 of 13
Any idea which is the window frame?
Message 8 of 13
Mark.Lancaster
Sorry that's the only one I know at the moment (Extrude Dialog)..   Had a case where it got moved off the screen and the normal ALT+Spacebar method wouldn't work.
Mark Lancaster
Message 9 of 13
DRoam
I did a quick registry compare just using Excel and it doesn't appear that changing the location of a sub-window has an affect on any of the registry keys in that location. I closed all but a single sub-window, took a registry snapshot, closed Inventor, took a snapshot, opened Inventor, opened a single sub-window, put it at a different location and size than before, closed Inventor, and took a snapshot. There was no difference in the registry for any of the snapshots. Maybe because we're dealing with a window and not a dialog box?
But now that I think about it, it doesn't make sense that there would be a key for this, because there would have to be a key for however many sub-windows you have open in a session, right? There might be a key which determines the initial opening location for new sub-windows, though. But I'm not sure how you'd find it.
Message 10 of 13
I found a temporary solution due to the desktop I use having an nVidia display with nView installed.
If you right click on the window, and go to nView options -> Individual Settings -> Edit and make sure that "Enable Child window spanning across multiple displays" is OFF, then it works as I'd prefer.
I'd honestly just like to have a solution no matter what hardware is in the system.
Message 11 of 13
howardlee306
At one point in time in Windows if you Shift+close (the red X) it was supposed to store the last position. I don't know if that works with Windows 8 or not.
Message 12 of 13
DRoam
Interesting... Inventor has crashed on me twice while trying to change this setting.
Message 13 of 13
DRoam
And that's three... I guess I'm destined to never experience this nice functionality you've found 😕
