Specify tightening torque in assembly 2d drawings.
I working on updating engineering documentation and I have a problem regarding specify tightening torque on bolts in an assembly.
To solve it, I have the following ideas, but was wondering if anyone else had this issue and maybe a better way of solving it.
I want to have all the bolts in an assembly specified with tightening torque. To do so I have the following options as I see it:
  • Add notes on all bots in the assembly (very time consuming and manual – not good)
  • Add a specified Coolum in the BOM list with tightening torque (could work, but again very manual)
  • Maybe use a Hole table in some way to display bolts And tightening torque, (I have not figured out quite how yet)
Anyone have any good ideas or experience with this?
Mark.Lancaster
@Anonymous
Welcome to the Autodesk User's Community..
Are you using your own hardware part files or from Inventor Content Center?
Mark Lancaster
Frederick_Law
Does the torque change for the same bolt in different assembly?
For example, 1/2-13 Grade 8 SHCS, same torque in all assembly?
