Spacemouse Pro Hotkeys not working in Inventor Professional 2020
my problem is that my newly bought Spacemouse Pro doesn´t really work when it comes to Hotkeys in Inventor.
I can move in the 3d field, rotate etc, but All Vision Hotkeys for top or side views or hotkeys with features like "Extrude" dont work.
I reinstalled the driver etc. but that didn´t help. The Addon "3dxInventor" is NOT installed. (Idk why)
That might be the problem but where can I get that extension or what can I do to fix the issue?
Thanks!
johnsonshiue
Hi! Please close Inventor when you try installing the 3D mouse driver. Reboot after that. Go to the following folder and see if the add-in file is indeed included there.
C:\ProgramData\Autodesk\Inventor 2020\Addins
Many thanks!
Software Test Engineer
CGBenner
@Anonymous  Did the information provided by @johnsonshiue  answer your question? If so, please use Accept Solution so that others may find this in the future. Thank you very much!
Chris Benner
I reinstalled the 3dconnexion software that morning you replied and installed it with inventor closed.
That fixed the problem so I will mark this answer as the solving idea, hope it helps others in the future.
Thanks for the reply 🙂
