Small issue here- Patterns and parameters, Inventor 2016 Sp1
Dan_Margulius
Advisor Advisor
Dan_Margulius
I am attching of what to be a very proud crane link.
I have an L parameter, U and U2 parametes who are all linked.
Whenever we change L we expect to see U and U2 change but then Inventor throws everything in different directions.
What i did wrong here?
Dan
WHolzwarth
Mirroring does it, if L=n*1250 (n=1,2,3,4,..)
2016 file attached
Walter
Walter Holzwarth
Dan_Margulius
Thank you, i will look at it. The reason I did not use Mirror or other smart features is because this part goes to Revit. Mirror is not supported as a BIM feature. Extrude with tapper also not supported. This is forcing me into a very basic workflow.
Dan
WHolzwarth
Oh, I see.
Does saving as IFC help out?
Walter Holzwarth
Dan_Margulius
I suggested to our Revit guys. They said that they want to change INV parameters and it is possible only in rfa format. If the INV parameters can be edited in ifc than it is a definitely WIN for me.
Dan
hosford
Dan
If you anchor sketch 12 your model will update properly.
Thaddeus Hosford
NUC9i9QNX i9-9980HK, Win 10 Pro 64
Nvidia GTX 1650
Inventor 2021
