Sliding an Object Along a Curved Surface
Good afternoon everyone,
I am attempting to make a ball joint "slide" through a curved rail, but I am having difficulties figuring out which constraints to use. I have made sure that both the rail and the ball joint are assigned to the contact set and the contact solver was activated. The curved rail was made originally as a long, normal rail, and then the "Bend Part" feature was used to bend the rail at the desired location. I am working with Inventor Professional 2014.
My first attempt involved making a cylindrical joint between the ball joint and the cross-section of the rail, but once the ball got to the curved portion of the rail, it fell off of the path and would not travel through the curved surface.
I have also tried a transitional constraint between the curved portion of the rail and the ball joint which was unsuccessful.
Finally, I tried mating the center point of the ball joint to the sketched curve line of the curved portion of the rail, but that was unsuccessful as well.
I don't know if the problem has to do with how I made the curved rail or in which constraints I am applying.
I have attached the assembly on which I am trying to guide the ball joint through the surface of the rail ("Ball Joint Slide on Rail") as well as the two part files in the assembly. Any help or advice will be greatly appreciated.
