Slash Key in Notes - not working
blair
Mentor Mentor
Message 1 of 12
blair
When in Notes environment for IPT and IAM files, the "/" key doesn't work. Yet in any other function/operation it works fine.
Am I the only one seeing this?
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
Replies (11)
Message 2 of 12
Curtis_Waguespack
Hi @blair
In see the same thing in 2020.... the back slash works as expected, but the forward slash key does nothing.... unless I hold the Shift key first... then it makes the slash all curvy 🙂
I hope this helps.
Curtis
Message 3 of 12
thenottakenname
Just checked, and I'm exhibiting similar behaviour. It looks like a few symbols aren't going in from that side of the keyboard, such as the period, forward slash, semicolon, right square bracket, and equal. May be more, but I'm just about to head home for the day.
Aaron Wilson
Inventor Professional 2022
AutoCAD 2020
Message 4 of 12
Cadmanto
@blair ,
Unless I am missing something, it works for me.
Windows 10 x64 -16GB Ram
Intel i7-6700 @ 3.41ghz
nVidia GTS 250 - 1 GB
Inventor Pro 2020
Best Regards,
Scott McFadden
(Colossians 3:23-25)
Message 5 of 12
Mark.Lancaster
@blair
You are talking about engineering notebook, correct?
I was thinking someone reported issues with the engineering notebook when 2020 was released or perhaps I'm getting old and thinking of something else   No comments ( @Curtis_Waguespack )
Update:  I used the forward slash on the numerical keyboard of the keyboard and it works there...   Now that's odd...
Mark Lancaster
Message 6 of 12
Curtis_Waguespack
@Mark.Lancaster wrote:
....No comments ( @Curtis_Waguespack )
This is an image ... not a comment :)This is an image ... not a comment 🙂
Message 7 of 12
Curtis_Waguespack
that worked for me too... that is strange 🤔
Message 8 of 12
Cadmanto
@Mark.Lancaster
To your point, if I use the notebook, I do see that the "/" does not work, but, if I use the one above the number pad it does.  Now, the "\" works fine.  If this is what @blair  is talking about.
Inventor Pro 2020
Best Regards,
Scott McFadden
Message 9 of 12
blair
This is only happening in the Engineering Notes.
Glad to others with the same issue and it's just not me. 🙂
Delta Tau Chi ΔΤΧ
Message 10 of 12
blair
Yes, only the forward slash on the numeric keypad works and not the forward slash on the main keyboard area.
Delta Tau Chi ΔΤΧ
Message 11 of 12
johnsonshiue
Hi Guys,
I am seeing the same behavior. For some reason, the forward slash is blocked. I cannot explain it. It looks like a bug to me. I will follow up with the project team to understand it better.
Many thanks!
Software Test Engineer
Message 12 of 12
thenottakenname
Just in case you missed it, there are several other symbols from that area of the keyboard that aren't working either. See my post above; hope that helps in the bug-quashing!
Aaron Wilson
AutoCAD 2020
