Solved by mcgyvr. Go to Solution.
Yep, I wish there was more freedom in controlling pattern instances.
Too bad you can't do it from the pattern feature like you can in Solidworks. I've got a ton of holes and a good many to skip as well and its pretty painful to find the right hole to suppress. Not too bad but certainly not 1 click per hole.
