Sketch Point Visibility
Message 1 of 9
Hi, I was wondering if there is a way to hide the points in 2D/3D sketches as shown in the photo. So far I am only able to change their color.
Replies (8)
Message 2 of 9
MikeKovacik4928
Ben
You can either turn off the object visibility of all 2d 3d sketches (see attached jpeg)
or turn off the visibility of that particular sketch (see other attached jpeg)
As far as I know there is no way to turn off that point only in that sketch.
However, some of our inventor experts out there might known of a way!
Michael Kovacik
2d & 3d Autocad and Inventor designer/draughtsman
Draughting/Designing (Manufacturing) (31 yrs)
-Drawing Board (3 yrs)
--Cad (28 yrs)
---Cadkey (4 yrs)
---AutoCAD 2d & 3d (16 yrs)
---Inventor (4 yrs)
---Autocad and Inventor Simultaneously (4 years)
---(and recently Autocad/Inventor Customisation)
Autodesk Product Design Suite Ultimate 2018
Autocad 2018, Inventor Pro 2018
(personal licensed copy)
Johannesburg, South Africa
(Impossible only means you haven't
found the solution yet)
Message 3 of 9
Hi Michael,
I would like to turn off all points on all sketches, but keep the lines visible.
Ben
Message 4 of 9
MikeKovacik4928
Ben
I don't know of any way of doing that.
Maybe someone else will know.
Mike
Message 5 of 9
johnsonshiue
Hi Ben,
Mike is right. There is no way that I am aware of to turn off visibility of sketch points. The points are there for a purpose. The points are pieces of sketch geometry actively participating in constraint solving. They are not just for display.
Many thanks!
Software Test Engineer
Message 6 of 9
Select those points, then in the properties window, change point styles to _no display, if you have one. Otherwise, create one for no display. Thanks
Message 7 of 9
JDMather
@Anonymous
Can you post example that existed in the year 2017 (you have responded to an old thread), or even in the year 2021?
Message 8 of 9
my mistake, I thought it was in civil3d. apologies
Message 9 of 9
