Hi all,
Forgive me if there is already a way to do this as I simply can't find it.
Say I draw a sketch on the face of a rectangle. I project all four edges as a reference and I need them for export for location.
I want to offset the sketch but do not want the whole entire rectangle. Is there any way to select the lines you want to offset without deleting the others just to re-project later?
picture attached
1. projected face then offset. forces entire profile to be offset.
2. projected one line. offset. then project the three remaining edges.
note: my profile is not nearly this simple so it becomes a pain to re-project every since line segement, arc, etc.
If i re-project the face i will have overlapping lines which doesn't help for CNC machining , waterjet programs, etc
basically i want to cut out a lot of extra steps with a possible shift click to offset specific lines that i would like to
thanks in advance
-Joe
edit:
the option exists and this is not a new idea.
