Sketch Driven pattern
ballnr
Message 1 of 8
ballnr
I try in Inventor 2018.0.1.
I cannot success to create it.
But I am not sure for my mistake.
Or a bug of software.
Please help and suggest.
kelly.young has embedded your image for clarity.
Replies (7)
Message 2 of 8
johnsonshiue
Hi! I guess there is a bit misunderstanding of how Sketch Driven Pattern works. Sketch Driven Pattern command is able to pattern selected features or bodies based on sketch points in a selected 2D or 3D sketch. The features or bodies will be populated to where the points are.
Your image shows you want to pattern features along a sketch path. You will need to use Rectangular Pattern command to do that. If you still cannot figure out, please feel free to post the file here or send it to me directly (johnson.shiue@autodesk.com). We can take a look and suggest the best workflow to use.
Many thanks!
Software Test Engineer
Message 3 of 8
ballnr
when you try in your computer.
Is it ok? (When you use command "Sketch Driven Pattern")
Because I need to check. That is only my computer or any computer have a same issue.
Message 4 of 8
johnsonshiue
Hi! It does work for me on my machine and other machines. I am not sure why it does not work for you. Could you attach the file here or send it to me directly?
Many thanks!
Message 5 of 8
ballnr
Thank you
Message 6 of 8
@johnsonshiue
Hi
What version is sketch driven pattern in part format available from?
Message 7 of 8
johnsonshiue
Hi! The Sketch Driven Pattern has been available since Inventor 2017.
Many thanks!
Message 8 of 8
@johnsonshiue
Thanks!
