Sketch Driven Pattern: Create Method - Adjust
bnielsenZNTXL
bnielsenZNTXL
Can someone describe to me what this Adjust option under the advanced settings for a Sketch Driven Pattern at the part level is doing in comparison to the Identical option? Also, when could I expect the Optimized value to not be greyed out and what's different about it? I'm currently working on placing fasteners all over an assembly in the exact same pattern but not at any regular intervals. This is a process that could be done at each location one at a time, and in the past that is how we did it. Unfortunately there is value in showing the fasteners at every spot, so I'm looking for a way to lean this process up. I've had some success with sketch driven pattern up to this point and I'm looking to take it further.
That being said if someone hit me with a silver bullet out of left field that has nothing to do with sketch driven pattern, I'm all ears.
Thanks!
Ben
kacper.suchomski
Hi
https://help.autodesk.com/view/INVNTOR/2026/ENU/?guid=GUID-9B3D1B72-340A-4F3E-9AD1-80E6DDD91ED2
These options apply equally to all pattern types.
You can find many examples of their use on YouTube.
Kacper Suchomski
bnielsenZNTXL
Thank you so much Kacper! Not totally sure how I missed that link in my search, but alas this has helped me out!
Cheers,
