Sketch does not extrude
Vagulus
Vagulus
Sketch25 in the IPT (in the ZIP attached because Autodesk Inventor Forum will not upload Autodesk Inventor Parts 🤔) will not extrude.  All I get when I try is
I have tried placing sketch points at each intersection but that didn't help.  All lines are fully constrained and, as far as I can find out all the lines join up but AI2018 is not having a bar of it.
Would someone please take pity on what remains of my hair and tell me why?
"If you can't explain it to a six-year-old,
you don't understand it yourself"
Albert Einstein
johnsonshiue
Hi! I believe this has something to do with the small arc tangent to the big arc. Place a point at the exact intersection and use Split command to split the big arc. After that, the profile should work.
Many thanks!
Software Test Engineer
Vagulus
Spot on (again) 😁
Thanks .
BTW: I think that is the first time I have used the 'Split' command.
Albert Einstein
