Sketch Cannot Finish
Message 1 of 11
Hello Inventor Community,
I am trying to make a sheet metal extrusion from a sketch (See attached) but somehow the error I am getting says : Part3: Errors occurredInventor problem.PNG during the update. When I expand it says: Extrusion1: Could not build this Extrusion. When I expand this it says, a profile loop could not be repaired after sketch geometry was edited or deleted. Use Edit feature to select the profile.
What could I be doing wrong?  The profile itself took me about an hour to trace and would be disappointing to start from scratch again.
Replies (10)
Message 2 of 11
JDMather
Attach file  here.
Message 3 of 11
I attached the file already. What format would you like it in sir?
Josh
Message 4 of 11
JDMather
An Inventor part format is *.ipt
Message 5 of 11
ShamjithPS
Hi @Anonymous,
You can always try Diagnosing the sketch using Sketch Doctor. Inventor will show you what's wrong with your sketch.
Open the sketch> right click>Sketch Doctor>Diagnose Sketch and Inventor will show you open loops, overlapping curves, and all. In most cases, it will be one of these errors which is not letting you Extrude
Shamjith P S
CAD Engineer (Facade)
Let's connect on LinkedIn
Autodesk Inventor Professional 2021
Message 6 of 11
johnsonshiue
Hi! After extruding the profile, what you are trying to do? Print it? This kind of artistic object is hard to build in Inventor since Inventor is a precise modeler. Every piece of geometry has to carry function and dimensions. I don't believe the deer profile in this case requires accuracy (up to 0.00001mm). There should be better tools to create such shape.
Many thanks!
Software Test Engineer
Message 7 of 11
My end goal is to CNC machine it. so after extrusion I will add a few features then make a DXF for laser cutting.
Message 8 of 11
Hi JD, I realized that I cannot save a sketch so I have attached the original email that I am trying to recreate for CNC.
 Please see attached.
Josh Okello
Message 9 of 11
JDMather
What is this?
Message 10 of 11
JDMather
What is this??
Message 11 of 11
JDMather
@Anonymous
See the Attached file.
