Single sketch line in Sweep command
glebmorgan
glebmorgan
I have a single 3D sketch with couple of rails (yellow ones) and a single 2D sketch with interconnection lines (white ones). I want to sweep each individual line segment in my 2D sketch using one adjusent profile as a path and another as a guide rail.
I aim to get a set of adjacent surfaces and stich them later into one solid.
The problem is that I can only select a whole loop as a sweep profile.
I have to create a couple of sketches on the same plane (at least, 3) to get all required lines separated from each other.
Am I supposed to do it this kind of way, or there is some proper approach to perform this line separating?
All sweep_paths_ends lie on the same plane, wich is the one the 2D sketch is on.
I am using Inventor 2019
JDMather
Do as 3 separate 2D sketches.
johnsonshiue
Hi! Like JD mentioned here, you can create separate sweep features. Or, you use Loft in this case. Here is what you need to do.
1) Create another 3D Sketch -> 3D Line -> connect the end points of the paths.
2) Loft -> Surface -> pick the two profile as a section and pick the newly create 3D sketch as another section -> pick the path as guide rails.
After that, you will need to use Rule surface or other surface features to create a watertight volume. Then use Sculpt or Stitch them back to a solid.
Please try and see if it works.
Many thanks!
Software Test Engineer
glebmorgan
@JDMather@johnsonshiue – thank you for replies!
@johnsonshiue, I had already tried Loft.
The trouble with Loft is that it tries to kind of smooth out the profile as it goes along the path.
That is not a desirable effect in my case, I need to have sharp edges at conjunctions.
I tried Loft one more time folowing your instructions, and got even worse kind of result than I used to 🙂
But, in fact, your answer gave me an idea to try to loft across the yellow profiles rather then along them.
Turned out I do not even need any additional guides here, just couple of seprate lofts.
Eventually I got time to try it, and now I got the exact result I wanted to achieve.
Let me accept my own message as a sollution here 🙂
