Single Row Ball Bearing
Hello, I am trying to find a single row ball bearing DIN 625 SKF (SKF 6001) but I cannot find it in the Content Center?
Accepted solutions (3)
swalton
I usually get models from the SKF website.  Not sure if the CC has what you need.
Steve Walton
Inventor 2025
Vault Professional 2025
mcgyvr
https://www.skf.com/group/products/bearings-units-housings/ball-bearings/deep-groove-ball-bearings/d...
jtylerbc
As the others already mentioned, I usually go to the manufacturer for this sort of thing.  However, in this case there is a DIN 625 SKF family in Content Center, and there is a part in the family with 6001 in the part number.
For clarification, is your problem that you didn't find the family, or that you didn't find the part you want in the family?
IgorMir
Hi Kevin,
Here it is. Right from the CC.
Cheers,
Igor.
Web: www.meqc.com.au
