@Anonymous
For me.. Standard workflow if you're using Vault, single project and properly organize your Vault structure.
Outside of Vault or not using Vault.. Its how you want to configure your Inventor infrastructure.. I have no opinion on that matter since I've seen and done it both ways. But here's something that I pass along when users are debating to use a single project file or mutiple project files for Inventor..
Many times users create mutiple project files for every project/design/job they do... But..
1. When you look at the given project file for every job.. They are the same settings except for the name of the project. So I ask why create the same project configuration over and over and over.. Make one..
2. Too many projects in the project editor dialog may lead to Inventor performance issues.. Although there's no guidelines, its recommended to keep less than 30 in that list and archive the rest.
3. I'm a big fan of keeping projects very simple and organize in Inventor. If the information is the same, make one like a Vault project as your standard and create custom ones when the project information is not-standard..
4. Continuation of item #1. Even if the workspace changes, a lot of times a new project file is created. But even under that condition, make your standard project file generic enough to point to all locations. I was taught many years ago with Inventor project files... The IPJ is the flashlight body.. Its settings is the beam of light.. If a single project file can beam the light to all your necessary information or standards, well you can control it with a single IPJ.
Now it may sound like I lean toward the single IPJ approach.. That may be the case in most situation where I've come across... However there's case (outside of Vault), where its mandatory to create a special IPJ for a given job.
Mark Lancaster
& Autodesk Services MarketPlace Provider
