By the attached video how would I do this in the sheet metal simulation in the inventor?
Solved by creocatia3d. Go to Solution.
Solved by mcgyvr. Go to Solution.
I think it is not possible to do this kind of animation in Inventor Sheet metal,
This Kind of animations are possible in 3ds Max you can model all the components in inventor and use 3ds max to make this kind of animations.
Regards
Boopathi..
Boopathi Sivakumar
Sr Application Engineer
www.usamcadsoft.in
Facebook | Twitter | LinkedIn
Sure it can be done but I don't think anyone will take the time to show you this one without being paid.
You are looking at a lot of work to do it.
Yep...
You just need to animate parameters and animate constraints in studio..
There are numerous tutorials on that on youtube,etc...
It certainly is a large task to ask someone to walk you through it but hopefully now that you know you need to animate parameters and animate constraints you can learn on your own..
A google search for these 2 phrases gets you tons of learning information..
"autodesk inventor animate parameters"
"autodesk inventor animate constraints"
http://lmgtfy.com/?q=autodesk+inventor+animate+parameters
http://lmgtfy.com/?q=autodesk+inventor+animate+constraints
