Simulation Environment of assembly with Imported Solidworks part files
I have been using Inventor 2017 Professional for about a year now, and I am starting to use it to run stress analysis simulations on an assembly model I am working on. Unfortunately, some of (not all of) the SolidWorks parts imported into the Inventor assembly do not seem to be interact-able for some of the usual features of Inventor such as the measurement tool, constraint setting, and the mesh command in the simulation environment.
The parts are enabled and visible under their extra options menu (usually accessed via right click) and under the "View" tab are set to render shaded with edges, but are still rendered by Inventor to look transparent. In the simulation environment (Environments>>Stress Analysis), whenever I try to select any feature (surface, edge) of them, Inventor ignores them and only lets me select features from the parts behind them.
When I try to set up constraints for the simulation environment (not in the usual assembly environment), I am also unable to select these parts to specifically apply forces or constraints to them. As mentioned before, when I run the mesh command, they are left out and actually completely disappear from the assembly, until I turn the mesh back off.
These parts are imported from an optics vendor (Thorlabs). As far as I can tell from re-trying to import one of the faulty parts, my import options are the same for each. I'm confused as to what could be causing this problem and if there is a way to make all the imported parts usable for Inventor's assembly simulation environment functions?
I have attached an assembly file with the parts from Thorlabs so you can see what I have described (zipped). When I open it, the GCM102/M, RC3, and CLS-SL are all rendered transparent, and are non-interact-able in the simulation environment.
