Hi Berryrr,
in Dynamic Simulation, to relax an action, you have to use the Input Grapher (berryrr_0.png).
Depending if you drive a load (force & torque) or an imposed motion, you have different solutions :
- "Free" option of a sector (berryrr_1.png).
Note for an imposed motion, it is not possible to "restart" the motion : if a sector is free then all the following sectors are free too.
- "Freeing condition" of a sector for an imposed motion : if the Driving force reaches a certain value then the imposed motion is stopped and the joint is released (berryrr_2.png). The Driving force is the value in the degree of freedom which is needed to imposed the motion taken in account all the dynamic of the system (masses, inertia, forces, springs, gravity, etc).
Note for a load (force & torque) the condition is an "Application condition" : the load is applied if ...
berryrr_3.png to illustrate the "freeing condition".
To complete the answer from Josh : the Moment vector of a joint gives the global moment but you have to select the Z component to have only the action around the Z axis, which is the rotation axis in a revolution joint. In my simple example, "U_imposed" (from Driving force) is equal to Moment.
Hope it gives ideas to simulate your mechanism.
JYves
