simulate the deformation of a solid in inventor
oneshortplanck
Message 1 of 8
oneshortplanck
Is it possible to simulate the deformation of a solid in inventor?
For example, the compression of a silicone oring or seal as it is secured into an assembly.
(eventualy I want to extrapolate from this example and visualise a complex sealing arragement involving a PMMA lens.)
(Inventor Profesional 2016)
(Dont think we have Nastran)
Replies (7)
Message 2 of 8
JDMather
When you refer to "simulate" do you want to merely have the part deform (physical) (in animation) or do you want to add a force and have the part deform (visual).
Message 3 of 8
oneshortplanck
the latter,
the end goal being if i apply force x to a lens, how much will an oring deform, and what will the stresses look like in the oring grove, the o-ring, and the plate that retains the oring.
http://www.engineersedge.com/general_engineering/image/oring_static_flange1.gif
Message 4 of 8
JDMather
Are the materials isotropic?
Can you attach the assembly (or mock-up of assembly if proprietary) here?
Message 5 of 8
oneshortplanck
Aluminium Housing and Retainer, PMMA Lens and Flurosilicone Seals (Oring and flat seal).
I will CAD up a Mock up.
Be rght Back.
Message 6 of 8
oneshortplanck
Here we go,
Message 7 of 8
LT.Rusty
Unfortunately, Inventor only works well with calculating deformations on isotropic materials, and even then only up to a certain point.  Once you get outside the range of elastic deformation and into the realm of plastic deformation instead, Inventor goes a little screwy.
Your seals may or may not be isotropic, but they are certainly going to be well outside the range of deformation that Inventor can calculate on its own.
Rusty
Message 8 of 8
oneshortplanck
Thankyou,
so i guess that Nastan is the tool to use?
