Simplify Assembly
Simplify Assembly
Simplify Assembly
Hi Autodesk Community I am trying to make a simplified step file from a big assembly. When i have included all the parts i want into the simplified view, i then export to CAD format (step file), but when i open the step file, some parts i did not include, are visible! What could i be doing wrong? Hope some of you guys can help me out, thanks.
smokes2998
Hi
You need to derive the assembly into a part. You have a 4 options when you derive an assembly into a part i would read up on the derive function the help file then pick the most appropriate function.
Once you derive it into a part export it to a step file.
JD  will be along to explain in more detail
mdavis22569
Welcome to the forum ...
Can you share the files .. or images?
Mike Davis
Okay, well it seems to do the trick by converting the "simplified assembly" into a "simplified part" and then export to step file.
Thank you for the fast answer.
JDMather
Try Shrinkwrap.
Thank you @JDMather, shrinkwrap also seems to be a really nice and fast way to simplify an assembly. Awesome!
