Announcements
Simple racking structure - Instability type 3 (expert advise needed)
I'm analyzing a racking structure with the different load scenario to obtain the sway value (column deflection).
Scenario 1: Fully loaded
Scenario 2: Fully loaded with omitting the load at the center of the bottom level.
For the scenario 1, the deflection value obtained quite similar to my manual calculation.
However, the scenario 2 has far difference result from the scenario 1.
The simulation also occurs the instability type 3 warning at the node which located on the top column.
Any advise to correct my scenario 2 result?
Please help. Thank you.
Replies (15)
JDMather
Can you attach your assembly here?
kelly.young
Autodesk Support
Autodesk Support
@Anonymous I see that you are visiting as a new member to the Inventor Forum.
Welcome to the Autodesk Community!
Without the files it is difficult to tell, but after looking at the images the displacement is 2.259e+38, it is not statically stable. If you can attach your files you might get a better answer from the community.
Please select the Accept as Solution button if a post solves your issue or answers your question.
Hi all,
Yep. I'm a newbie either forum or Inventor. Please give some helps on the issue. Here attached the file for your study.
The continuous load 31 and 32 are suppressed to illustrate that one of the load being taken out from the racking.
Result shown that instability occurs with huge deflection on the column but the manual calculation shown that a little bit rise in the deflection value only.
Hope you understand my english.
Thank you.
Does anyone can help?
Thank you
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
Could you generate Robot rtd file from Inventor and attach it so that i could check the reason for the reported instability?
Artur Kosakowski
Here is the file.
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
You need to change the solution method from the default BFGS (usually faster) to the Full_Newton-Raphson (usually better converging) for by marking the indicated check box. I'm attaching the model with the results as well.
Artur Kosakowski
Roelof.Feijen
If you remove the Beam Release from the Beams 194 and 195 there's no problem.
If you unsuppress the Continuous Load 31 and 32 there's also no problem.
Not sure why. Maybe to much degrees of freedom?
I saved your model in Inventor 2018 and attached it again, because your model did come with a lot of unresolved parts.
Maybe someone else has an idea?
Roelof Feijen
If my post answers your question, please click the "Accept Solution" button. This helps everyone find answers more quickly!
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Roelof.Feijen
If the calculations were run with Robot geometrical kernel the reason for extremely large displacement was that nonlinear analysis diverged.
If you use the settings I indicated in my previous answer (with no changes done to a model itself) it will converge and the results will look like this:
I hope this helps.
Artur Kosakowski
Roelof.Feijen
Hi @Artur.Kosakowski,
Please tell us how to change the solution method from the default BFGS to the Full_Newton-Raphson in Inventor Frame Analysis.
That's what this post is about, not Robot Structural Analysis.
Roelof Feijen
Thank you for the advise from @Roelof.Feijen @Artur.Kosakowski
I'm agreed with @Roelof.Feijen. It is better if @Artur.Kosakowski could provide us how to change the solution method as I only have Inventor in my pc. Perhaps my problem will be solved after I change the solution method.
Thank you.
EL
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
I fully understand your point but if it was available from Inventor UI I would (in addition to the explanation what actually happened) have explained how to change it. Smiley Sad
I'll try to determine if it can be done in any other way (e.g. via API or some external file) but as I have to discuss this with the development team this is going to take me some time. In addition I'm going to suggest them to change the default method from BFGS to FNR if possible (the difficulty is that the kernel is taken from RSA which has got the tools for setting its parameters and I'm not sure if they can be changed in any other way).
Going back to the model itself I'd like to focus your attention on the fact that for such kinds of structures you may actually want to include some other factors and check some other types of results in addition to the level of stress. As the posts of a racking may not be 'perfectly' vertical and it may also be assembled as not perfectly vertical either you can think of adding both local
and global imperfections e.g. as notional loads
and then see what the influence they will have (on both deformation and stability of the structure) when you run the 2nd order and buckling analysis.
Artur Kosakowski
I did consider the global imperfection in my model by adding some point load at the side of the racking. This model is exactly designed based on the Europe racking standard. If I removed all the horizontal load, it becomes stable and deflection is deemed within the acceptable range.
Besides, the shown deflection only match with my calculation with taking account of first order effect. If I consider second order effect in the calculation, the deflection value is larger than the result which cannot be done by the Inventor frame analysis.
I can't find any way to input the initial imperfection and global imperfection like you mentioned in the Inventor frame analysis. Anyway, thank you for your effort on solving the problem. Please advise if you have better solution.
Thank you,
EL
Hard to tell without the model, but it might be possible is about the constraints. Whenever I model a structure if I miss a constraint, displacements occur in a wide variety of strange behaviors.
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
I have determined that neither by any internal configuration file nor by Inventor API it is possible to change the parameters of nonlinear analysis in the Frame Analysis module Smiley Sad
If you want to try use RSA for this design (including the 2nd order analysis) I'll be happy to assist.
I think that you may try to replace posts modeled as single elements with chains of smaller ones forming a bow shapes. Luckily as the model is symmetrical if they are pointing towards the direction of the horizontal forces you defined you should be able to catch the worsts case scenario in a single model.
Artur Kosakowski
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
