Shrink fit contact -anomaly -
admaiora
Mentor Mentor
Message 1 of 13
admaiora
I have noted a discrepancy between 2016 and 2017 realeses.(stress analysis)
2016, no loads, shrink fit contact.
I can run the analysis and obtain contact pressure results.
2017, same assembly, same settings. no loads, shrink fit contact.
I can't run the analysis.
Admaiora
_____________________________________________________________________________
Facebook | Twitter | Youtube
Replies (12)
Message 2 of 13
Xun.Zhang
Hi Admaiora,
Would you mind send me your dataset and I can help try in my end to understand it better.
Email: [email protected]
Thanks!
Xun
Message 3 of 13
admaiora
Hi Xun,
you will have the sane results with every assembly.
Anyway you will find 2 samples.
The Stress Analysis workflow:
- we want to analize contact pressure between two forced parts.
- parts has interferences (wanted)
- just use fixed and frictionless constraints
- no load needs to be added
- automatic contacts, then convert the only bonded in Shrink Fit/Sliding.
-Then run aanalysis
Until 2016 we can run analysis of this time (even if there are no loads)
With 2017, same models, same settings, same analysis, we can't run analysis because there are no loads.
Thank you Xun
Admaiora
Message 4 of 13
karthur1
I tried it in 2018 and it will not run.  Get the same "No Load defined" error.
Message 5 of 13
admaiora
Thank you @karthur1
to this end, the Shirk Fit Contact is useless for static contact pressure studies.
Admaiora
Message 6 of 13
admaiora
Any updates?
Admaiora
Message 7 of 13
kelly.young
Autodesk Support
Autodesk Support
@admaiora after investigating a bit, in the older version it states the error No load defined but still lets you click the Run button.
In the 2018 version the Run button is greyed out with these same settings.
I'm not sure if this was a conscious effort to eliminate allowing the simulation to be run without the load and was fixed, which in your case is now "broken" as far as your use and functionality.
I sent the issue to the development team so I'll see what I can find and report back.
Please select the Accept as Solution button if a post solves your issue or answers your question.
Message 8 of 13
johnsonshiue
Hi Guys,
Indeed, there seems to be a behavioral change here. It is not clear to me why the change happened. I did try tricking the solver by adding a non-essential load (very small pressure like 0.0000001 MPa) and the solve did go through. But, I am not sure if the result is consistent with 2016 since I don't have access to the release at the moment. I will try it on Monday.
Many thanks!
Software Test Engineer
Message 9 of 13
johnsonshiue
Hi admaiora,
I just tried it on Inventor Pro 2016. I was not able to start a Simulation. Is it on Inventor FEA or it was on NASTRAN In-CAD?
Many thanks!
Message 10 of 13
admaiora
Inventor FEA, Inv Pro 2016
Admaiora
Message 11 of 13
johnsonshiue
Hi admaiora,
Then I cannot explain the behavior. On 2016, I am not able to start a Simulation without a load. Do you still have access to 2016?
Many thanks!
Message 12 of 13
admaiora
Hi @johnsonshiue for your constant support!
Here as I always used this kind of contact:
Admaiora
Message 13 of 13
kelly.young
Autodesk Support
Autodesk Support
@johnsonshiue here are the 2016 files I made real quick to test the setup, @admaiora can you verify this is how you want it?
It gives the No Load defined error but the Run box is not greyed out like in newer version. Hope that clears it up a bit.
