shrink feature
shrink feature
ZaC-04
shrink feature
ZaC-04
How do i make the Sculpt feature in the model smaller by 0.001 so it is not touching any of the walls on the inside of the plastic container? [shrink sculpt feature by 0.001]
Model: Inventor 2022
Thank you
Gabriel_Watson
Select your three surfaces (the two boundary patches "lids", plus the offset surface) and "Stitch" to form a solid out of those. Then direct edit to scale:
3D Model (tab) > Modify (panel) > Direct (edit) > Scale, using different scales to measure the end result until it matches closest to your desired 0.001 (I am not sure you can scale to match that measure perfectly otherwise).
SharkDesign
Turn off visibility of Solid1
Then use thicken. You can window select everything by dragging a box around it.
Turn visibility of solid1 back on
  Inventor Certified Professional
ZaC-04
Thank you
