Showing Assembly as single part in structured BoM
I am trying to set up a sub-assembly so that when it is included in a higher level assembly, only the sub-assembly comes through on to a structured BoM (as if it were a single part) and not all the individual components within that sub-assembly. However I also want to be able to create a separate drawing for that sub-assembly which references all the individual parts in a parts list on the drawing. As an example I have an e-chain. It is made up of several links and internal separators. I will create a separate drawing of the e-chain with all the details of the links and separator, but I want the e-chain to show up as a single part on the top level structed BoM (all levels) and not all the individual parts. I have tried using several different combinations of BoM structures (phantom, reference, inseparable etc.) but I can't get it to work the way I want. If I set each part in the sub-assembly to phantom then it doesn't show on the top level BoM but it also doesn't show up on the parts list for the sub-assembly. If I set the sub-assembly to purchased or inseparable then all the individual parts still come through on the top level structured BoM. Is it possible to achieve what I want? I am using inventor 2021.
Thanks in advance.
