Announcements
Show tangent edges on view placement
YannickEnrico
YannickEnrico
Wow. What a different UI to look at....
Anyhow.
I have set tangent edges visible on view placement so it does so automatically. However, that doesn't always seem to be the case.
Creating two new DWG's of a 40x40x2 profile creates one with tangent edges and one without.
Can it be because inventor suggests a different view scale for the two?
And if that's the case, how do I enforce it anyway, without having to change it every time I place a view?
_______________________________________________________________________________________
Intel Core i9-14900KF
64 GB DDR5 6000 MHz
2TB WD_BLACK
RTX A4000
Inventor 2024 Professional
Replies (12)
Xun.Zhang
I am not quite follow your question, could you attach any more information like images or videos or document to describe it more?
Thanks!
Xun
YannickEnrico
These two drawings were created consecutively. Both starting with the same view and then projected the same way.
One of them had tangent edges enabled. One of them didn't, as you can see on these screenshots.
That is so despite my best efforts to set up everything on my first view so it supposedly remembers for the next base view.
Edit:
The only difference in the behavior of these two drawings was that one of them started at suggested 1:5 while the other started at 1:10 or 1:20 (can't remember)
64 GB DDR5 6000 MHz
2TB WD_BLACK
RTX A4000
t_pcoll
I'm not sure I understand correctly.  Base view dialog during forward create remembers some of the settings based on last view created and then those settings are used as defaults for next view creation. Tangent edges checkbox is included.
However, there are several sets of defaults kept separately per file type (Parts, Assemblies and Presentations) and also another sets per view orientation (different set of defaults for ISO projected vs Ortho projected etc).
So normally if you create an Ortho view from a Part using Tangent edges enabled then next Ortho view from different Part should default to Tangent edges enabled too. Please note next Ortho view of an Assembly may default to different settings since defaults used for Parts don't apply to views of assemblies.
Can you please describe in more detail your steps or record a video or provide dataset?
Ladislav
YannickEnrico
Both of those drawings are parts, and with the same projections.
I'll accept your answer as solution, not because I found a reason why it behaved like this, but because I cannot seem to reproduce it now.
I have been extra attentive in regards to setting up the default view for both parts and assemblies after an earlier question about the same.
The issue here was that despite setting everything up in the first view, at least this one part didn't stick to it.
I can say this about five drawings that were created consecutively:
40x40x2 no 34: No tangent edges
40x40x2 no 35: No tangent edges
40x40x2 no 36: Tangent Edges
40x40x2 no 38: Tangent Edges
40x40x2 no 39: No tangent edges
40x40x2 no 40: Tangent edges
All drawings were made yesterday and in the same order as the list using just the settings I set up first time I changed my base projection settings.
I was just wondering if there were any known bugs in regards to this and / or any fixes in regards to this.
64 GB DDR5 6000 MHz
2TB WD_BLACK
RTX A4000
t_pcoll
Thanks for watching this and letting us know. I'm sorry it's not clear what the problem was.
The only issues in this area I'm aware of were problems with saving the defaults to Windows registers during Inventor exit. This caused that defaults didn't stick between Inventor sessions -but I believe we have fixed this couple years ago. Though, it still may happen if Inventor does not exit cleanly. But it does not look to be your case.
I'll be happy take closer look if you find this happen again.
Ladislav
YannickEnrico
Hello @t_pcoll and @Xun.Zhang
So I just managed to reproduce it! And screencast it as well!
It's the exact same part, and it appears that tangent edges visibility is based on the view orientation. The screencast should be self-explanatory
However... Creating a new drawing and using the "successful" first view, it was created without tangent edges as well.... See screenshot below. This issue makes no sense to me
undefined
64 GB DDR5 6000 MHz
2TB WD_BLACK
RTX A4000
YannickEnrico
It was tied to view orientation one way or another.
Unfortunately I cannot reproduce it now, because I oriented it in a way where tangent edges disappeared, and then clicked tangent edges again. Now it's on all view orientation placements.
64 GB DDR5 6000 MHz
2TB WD_BLACK
RTX A4000
t_pcoll
So it looks like Top and Front views don't share the same settings. I think this may be somehow related to Home view setting in the part.
Can you please post here or send me to ladislav.pcola(at)autodesk.com that part?
Ladislav
YannickEnrico
It's a family problem, then, because the same thing happened when I tested other 40x40x2 parts.
All made with frame generator from the same family.
See attached part.
64 GB DDR5 6000 MHz
2TB WD_BLACK
RTX A4000
t_pcoll
Many thanks for reporting this and for all the details you provided!
This is actually a great catch. I was able to reproduce and identify the problem. For the future reference this is internally tracked as "INVGEN-14534".
Thanks again!
Ladislav
YannickEnrico
Thanks for getting back to me on this.
Knowing it's a bug that's gonna be fixed makes it slightly less frustrating looking at drawings after running on Autopilot for some time 😉
64 GB DDR5 6000 MHz
2TB WD_BLACK
RTX A4000
YannickEnrico
Hello @t_pcoll
Is this behavior intentional or a part of the bug? Or another bug? Notice how the view placement is the same face. The only difference is whether the profile is horizontal or vertical.
This time it's Inventor 2019.1 and the family is 40x40x3
It seems to be fixed after enabling tangent edges on view placement of the second view, so no need for a solution.
Just wanted to clear whether this was a bug you should investigate, a part of the already isolated bug, or intentional behaviour
64 GB DDR5 6000 MHz
2TB WD_BLACK
RTX A4000
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
