Hello everyone,
I'm currently working on an assembly with parts that are delivered to us as a set.
On the drawing I want to show them like normal, but because they are delivered as one set I must exclude them from count. Otherwise there is a risk that the warehouse is given it double to the mechanic.
(for example an engine is delivered including oil filter and fuel pump, but they are mounted separately on a frame, than on that drawing I want to let them know which part they need, but the count must be on 0 because the mechanic should have it already)
Normally I would go to the Bill of Materials of the assembly and put them on 0 there and that works fine on the drawing as well. But now I use it on the drawing with a BOM splitted in view representations, With the limit QTY on and then they are counted in that BOM again.
This hints me to think that I does not use the proper method to exclude parts from count without removing them completely from the BOM, I have searched for a check box exclude from count but I could not find it.
Thanks in advance
Greeting Bryan
