Show Extended Names
Show Extended Names
BCrosby
Show Extended Names
BCrosby
My "Show Extended Names" option isn't working in my iam files but it is working in my ipt files.
Any thoughts as to why?
Bruce M. Crosby
Broomfield
Engineering Department
GIGABYTE Z490 Vision D (Intel LGA1200/Z490/ATX/3xM.2/Dual Thunderbolt 3/SATA 6Gb/s/USB 3.2 Gen 2/Intel WiFi 6/Direct 12 Phase Digital Power/Intel 2.5G LAN/Motherboard)
Intel Core i7-10700K
Samsung (MZ-V7E1T0BW) 970 EVO SSD 1TB - M.2 NVMePNY Quadro P5000 VCQP5000-PB 16GB
Crucial Ballistix 3200 MHz DDR4 DRAM Desktop Gaming Memory Kit 128GB 32GBx4
Dell Ultrasharp U4919DW Curved 32:9 49” Display
Windows 10 Professional 64 Bit
CAT 7 Ethernet
HP Designjet T3500
3D Connexion SpaceMouse Enterprise
3D Connexion CadMouse
Autodesk Vault Basic 2020
Autodesk Inventor Professional 2020
Autodesk AutoCAD Mechanical 2020
mdavis22569
Can you post an image ...
Also ..I'm assuming you've looked at this:
https://knowledge.autodesk.com/support/inventor-products/learn-explore/caas/CloudHelp/cloudhelp/2016...
Select Show Extended Names in the Filter menu to display detailed information about part features.
Extended feature names are available in the Part, Sheet Metal Part, Assembly Modeling View, and Drawing environments. Format or content of extending strings cannot be changed.
Mike Davis
BCrosby
To be clear... The extended names are now showing in a weldment.iam file under the machining process.
they are showing up in a ipt file.
Bruce M. Crosby
Broomfield
CAT 7 Ethernet
HP Designjet T3500
Curtis_Waguespack
Hi BCrosby,
To show the extended name information of parts in the assembly, you must change the browser view from Assembly View to Modeling View, this will display the extended information of the features in the parts.
I think that assembly features simply do not have the ability to display extended data at this point, but I could not find anything stating so clearly in a quick search of the help files.
So I think it is just not psossible to do this for assembly (weldment) features?
I hope this helps.
Curtis
BCrosby
I toggled between assembly view and modeling view with the "Show Extended
Names" check on and they don't show up in either situation in the iam file.
Kinda strange that the option would be available to turn on if the
capability isn't there.
_____
Bruce M. Crosby
P.O. Box 157
113 Still River Road
Bolton, MA 01740 USA
Phone: (978)779-6600 x306
Fax: (978)779-2954
Email: BCrosby@BroomfieldUSA.com
Website:www.BroomfieldUSA.com
_____
P We encourage you to print this email only if it is absolutely necessary.
_____
WARNING - CONFIDENTIAL INFORMATION: The information contained in this e-mail
may contain trade secrets, confidential or privileged information belonging
to Broomfield Laboratories and is intended solely for the use of the
intended recipient(s). Unauthorized review, forwarding, printing, copying,
scanning, distribution, or use of such information is strictly prohibited
and may be unlawful. If you received this message in error, or have reason
to believe that you are not authorized to receive it, please promptly notify
the sender by reply e-mail and delete this message, including any attached
documents or files.
Bruce M. Crosby
Broomfield
CAT 7 Ethernet
HP Designjet T3500
Curtis_Waguespack
Hi BCrosby,
The capability in assemblies is there, it turns on extended information for the part features in the assembly tree, and it turns on the Relationships extended information (for constraints, etc) it just doesn't do anything for assembly features.
I hope this helps.
Curtis
