Shortcut to open iLogic form
I am trying to create a shortcut to open an ilogic form to avoid me having to use the tabs on the menus, either via keyboard or marking menu (rmb).
I hope someone can help as i'm struggling to find a solution at the moment.
Adam
mcgyvr
A few different ways that I know of..
#1-Write a Vba Macro to trigger a rule that shows the form.. Creating a hotkey for that macro (I believe there are some limitations to that)
#2-Create an ilogic rule to show the form and simply setting that to fire on the "before save" event trigger or something like so that you just need to do the hotkey for save and the rule would fire and open the form and then save right after..
https://www.cadlinecommunity.co.uk/hc/en-us/articles/115000859309-Inventor-Run-iLogic-Rules-from-you...
https://www.youtube.com/watch?v=eQC4qUU2a00
The easiest way is to use an iTrigger, although they are not always very reliable!
This code should work, you may need to run it, then edit a parameters, edit the rule again, and it should fire from the iTrigger button.
trigger = iTrigger0
iLogicForm.Show("Form 1")
 Once you get the iTrigger working, you can assign a shortcut to the iTrigger command
JanekPop
Do these solutions assume that the iLogic form is already present in the file (the iLogic browser Forms tab not the Global Forms tab)?  With the iTrigger0 involved I am assuming so...
When I open an old part file (i.e. created with an old template), I run an external rule without the 'trigger = iTrigger0' line to show my form, yet it comes up with an error saying that the form cannot be found, even though I have the form saved in the Global Forms folder.
Janek
SharkDesign
ilogicform.show will only show document forms, you need to use:
iLogicForm.ShowGlobal
  Inventor Certified Professional
JanekPop
Thank you.
rhasell
Hi
Have you tried Button Constructor. Place a button for the form on the ribbon.
You can the add the form to the right click menu.
https://apps.autodesk.com/INVNTOR/en/Detail/Index?id=2268703737300536294&appLang=en&os=Win64
Reg
2026.1
