Ships Hull
Ships Hull
Message 1 of 29
Ships Hull
Hi all,
I have access to frame drawings for a 90m ship. I am trying to draw the ships hull in Inventor. I was hoping to redraw each frame and then use the loft command to connect each individual frame together.
Can anyone advise if this is correct, or is there a way I could transfer each individual frame outline into inventor and save me drawing each one.
Anyone with advice or suggestions will be appreciated.
Niall
Replies (28)
Message 2 of 29
JDMather
@Anonymous wrote:
1. I have access to frame drawings for a 90m ship.
2. I am trying to draw the ships hull in Inventor.
3.  ...or is there a way I could transfer each individual frame outline into inventor and save me drawing each one.
1. What format is this information? Paper? DWG file? Other?
2. Attach Inventor file(s) of your attempt here.
3. What format (See #1)?
This does not sound like a beginner endeavor.
Are you a student?  How much training and experience do you have with Inventor?
Message 3 of 29
Hi JDMather,
I have attached a pdf drawing showing the details of some of the type of frames for the outline of the ships hull.
What I was hoping to achieve through Inventor was to know if it was possible to transfer each individual from from the stern  to the bow approximately 122 frames and then use the loft command to connect each frame shape to form the hull framework. Is this possible as an AutoCad file.
Or can I have to draw each individual frame as apart drawing and then create an assembly before using the loft option.
Maybe you could suggest or advise if this is a choice or demonstrate another alternative.
Niall
Message 4 of 29
JDMather
I would do this as multi-body solids and then push out the assembly, but I have been using Inventor for 17 yrs.
I would expect to complete a couple of years worth of projects of increasing complexity leading up to a project of this complexity - not exactly an endeavor for a beginner in Inventor.
Message 5 of 29
Hi JDMather,
Re: Youtube.com/watch?v=PaPHNXy59Nc
I was thinking of the procedure as shown in the above video for your reference, I have used the loft command during my experience with various detailed constructions.
I was considering following a similar technique as used here, by re-drawing each frame form as a solid shape through continuous work planes and connecting each together as I progressed, starting at the back (stern) frame shape and moving along, drawing each separate frame towards the front(bow) on a new work plane  in the aim of creating and connecting all the frames until the full length of the ship's hull feature. I know its a slow and long procedure but I think it may work.
Any views on this approach!
Do you think this option would work as a way of creating a reasonable hull shape? Or is there a way to cut and paste each individual frame shape into Inventor and then join them in sequence using the loft command, or any other command.
I am trying to produce this solid hull form which I can then use as a base to draw the top structure and re-create a 3D replica model of the ship.
Again your advice and suggestions are appreciated.
Niall
Message 6 of 29
JDMather
@Anonymous wrote:
...starting at the back (stern) frame shape...
Create first sketch and then Attach your *.ipt file here for comment.
Message 7 of 29
As a naval architect, I do not turn to Inventor to create the shape of a vessel's hull (except, perhaps, in the case of a simple box-like barge form). When I want to do what you are attempting, I import the frame shapes from your pdf in to a surface modeling program. Each frame is positioned at the correct location along the length of the vessel. Next you stretch a C-spline surface over them and there you are. I employ MultiSurf for this task; there are others to choose from also. The resulting surface model of the hull form can then be imported as an iges file in to Inventor. Proceed in IV to build the superstructure above the sheer line (deck edge line).
Edmund Glowacki, P.E.
Naval Architect
GLOWACKI ENGINEERING
1835 East West Parkway, Suite 10
Fleming Island, Florida 32003 USA
glowackiengineering.com
(904) 278-8870 ph
(904) 923-4242 c
(904) 278-8826 fx
ed@glowackiengineering.com
Message 8 of 29
Hi Edmund,
Thanking you for the very interesting information and insight into this process. I was hoping you may have some links or references of any tutorials or youtube videos  showing this task being used, or links to something similar.
This would help me greatly, as I would  like to attempt this procedure and  create the shape of a vessel's hull.
Any further help or suggestions you can provide will be appreciated.
Regards
Niall
Message 9 of 29
lena.talkhina
Hello @Anonymous  !
Great to see you here on Inventor Forum.
Did you find a solution?
If yes, please click on the "Accept as Solution" button as then also other community users can easily find and benefit from the information.
If not please don't hesitate to give an update here in your topic so all members know what ́s the progression on your question is and what might be helpful to achieve what you ́re looking for. 🙂
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям! | Do you find the posts helpful? "LIKE" these posts!
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
Лена Талхина/Lena Talkhina
Менеджер Сообщества - Русский/Community Manager - Russian
Message 10 of 29
Hi Lena,
According to Edmund Glowacki Naval Architect, P.E. reply to me recently he suggested you import the frame shapes from your pdf in to a surface modeling program. Each frame is positioned at the correct location along the length of the vessel. Next you stretch a C-spline surface over them and there you are. I employ MultiSurf for this task; there are others to choose from also. The resulting surface model of the hull form can then be imported as an iges file in to Inventor. Proceed in IV to build the superstructure above the sheer line (deck edge line).
I was hoping you could look at this procedure and advise or forward any links to similar tutorials or youtube clips that may demonstrate examples of this course of action being done.
Any help or links you can suggestion will be appreciated.
Niall
Message 11 of 29
S_May
Hi @Anonymous
hier ein Muster...
Message 12 of 29
S_May
f5676336-9903-4d19-8dd2-4a6a1b673f88,640,620
Message 13 of 29
That video is fine for drawing a canoe using Inventor and shows the basic commands, but I was hoping that someone could show a link to an online video or tutorial demonstrating how to import ships hull frame shapes from pdf into a surface modeling program such as Multisurf. Each frame is positioned at the correct location along the length of the vessel in question and then you stretch a C-spline surface over them to create and exterior side.
The resulting surface model of the hull form can then be imported as an iges file in to Inventor. You should the be able to proceed in Inventor to build the superstructure above the sheer line (deck edge line).
Anyone who has links to tutorials or videos for the above methods will be appreciated.
Niall
Message 14 of 29
S_May
Message 15 of 29
Niall,
The process I simply described above requires familiarity with somewhat complex techniques to:
1. Convert a pdf of a ship frame in to a dxf that can be loaded in to Autocad (ACAD).
2. In ACAD each frame must be cleaned up. Typically, a lot of extraneous clutter must be removed from each frame, leaving only the outline of the frame's shape.
3. Each cleaned up frame is imported in to MultiSurf (MS) as a dxf entity. Each one may need to be rotated to get its orientation correct. Additionally each frame may need to be "scaled" to get it to its correct size.
4. Then each frame would be "shifted" to its correct longitudinal location along the vessel's length.
5. I use these imported frames as templates to draw new, more pleasing curves in MS that are as close in shape to each frame as I can get. I strive to make each new curve as "fair" (smooth) as possible, where the imported dxf curves are typically relatively crude and locally bumpy.
6. These new MS curves are then used as "master curves", as the basis for a C-spline surface which closely approximates the desired vessel hull.
Look up MS on the web and you may find some tutorial videos that show how to create curves, and how to utilize those curves to create surfaces.
Good luck,
- Ed
Naval Architect
(904) 278-8870 ph
(904) 923-4242 c
(904) 278-8826 fx
Message 16 of 29
Thanking you EdGlowacki
Message 17 of 29
You need AutoCAD 2017 or later mind! But yes, finally, it can be done without any questionable third party apps! AutoCAD can now convert a PDF to DWG and it seems to do it pretty nicely! This video will show you how to.
https://www.youtube.com/watch?v=AOVt9597kLg
Message 18 of 29
S_May
Hi @Anonymous
they will not succeed in the inventor with the autocad sketches, everything will stay green
I'll show you a method about surface models
Message 19 of 29
I appreciate your advice S_May.
Message 20 of 29
S_May
Hi @Anonymous
Here is a pattern in the rush of the day…. 😁
