Sheet Metal Unfold Rule Error after modifying
I have an unfold rule made using an imported bend table that works according to a previous shop managers unfold parameters. Now we're going back to the original way and so I tried changing the unfold method from "bend table" to "custom equation" and adding in those parameters as seen in attachment "error-1". Although, when I try saving that error pops up and haven't found a related article on the topic. The bend table method has worked just fine, so it can't be referencing that. Only does this error when I try adding another unfold method to the existing rule. Would greatly appreciate the help!
Secondly, we're receiving customer parts from canada so they're using metric settings/inputs for everything and tucked corners instead of corner-corner it should be (per our bid). Trying to find the easiest way to get the custom equation into their models and adjust without it messing up all their sketches and flanges created, but finding it hard to do. I tried testing the bend table on their part and it still wasn't matching the flat layout dims it should have with a 90 & 45 degree flange like it does with the same part if I make from scratch. Will I need a metric version of the equation in attachment, or does going to "document settings" in their part file and changing units to inches not solve this?
