How can I make a sheet metal part with a slight bend?
basically I'm making a drain pan, it'll have a hole in the center for draining. The shape would be rectangle, but with bends going from one corner to the other opposite. how can I make this a sheet metal part to lay flat? I don't want seams or anything, almost like a stamp of sorts.
Solved by mcgyvr. Go to Solution.
Inventor is not capable of doing a "Sheet Metal Flat Pattern" for stamped parts like that..
You can use the "Unwrap" function to generate a sudo flat though if you have one of the newer versions of Inventor with that function (2021 and newer I believe)
You might be able to use a punch tool to make the crossbreak...
This grabcad file might help. https://grabcad.com/library/crossbreak-punch-tool
Steve Walton
