- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Good Day All,
I have attached a sheet metal part (2014 .ipt) and am having issues trying to use the rip command, maybe my understanding of the rip command is unclear, and I should probably just create a sketch and extrude a slit.
Using the image below as a reference,
What I want to do is to create a rip or slit from P1 to P2, which will give me face C.
After this rip, I want to bend face C at P1 so that it is parallel to face A, leaving face B at its current state.
(the construction lines are from the existing frame that this will be welded to.)
My 2 solutions are to create this slit using the extrude command then fold,
or to cut face C out completely and add a flange to that cut edge.
I am just curious why the rip command is not letting me create a slit from P1 to P2.
