Sheet metal _ Multi-Body
CWC_Drawing_Office
Message 1 of 12
CWC_Drawing_Office
Hi all,
I don't believe this to be a Inventor question as much as it is a manufacturing question.
Please see below image for what I am referring to, encircled is a lofted profile to create a mitered edge. It seems as though the edge is "Rolling" when it transitions into the next vertical line.
This part is going to be laser cut and as such I would like to know if it is okay, because it will have to be welded? Any input is welcome!
Thanks in advance.
Replies (11)
Message 2 of 12
gcoombridge
Haven't looked at your files because I am away from my laptop but if that edge is on a flat plane I would say it is not ideal. All edges should be perpendicular to the sheet face...
That said you can just tweak the flat pattern dxf export in AutoCAD.
Use iLogic Copy? Please consider voting for this long overdue idea (not mine):https://forums.autodesk.com/t5/inventor-ideas/string-replace-for-ilogic-design-copy/idi-p/3821399
Message 3 of 12
SharkDesign
Why have you used loft at all? I would do this as a dead simple face with two flanges attached.
Also, you should check that whoever is bending it has the right tools because your sides are slightly longer than the width of the part. Not by a huge amount so it'll probably be fine.
You get this at the end, which a laser cutter wouldn't do. This is the reason you are getting a 'rolling edge,' the sheet does not have a square end.
  Inventor Certified Professional
Message 4 of 12
SharkDesign
So either three shapes like this:
Or one part like this:
and weld the inside on after
Message 5 of 12
SharkDesign
This cut is your real issue:
It leaves you with an angled cut across the bend and an angled edge to the sheet.
p.s. don't see any issue with welding that stuff.
Message 6 of 12
johnsonshiue
Hi! This is a very interesting challenge. The seemingly simple design can be tricky to do. There are multiple ways to do this. Without altering the model too much, I used Thicken features repeatedly to help fix up the side faces. Also, instead of Loft solid, I used Loft surface to ensure consistent thickness. Please take a look at the attached part.
Many thanks!
Software Test Engineer
Message 7 of 12
CWC_Drawing_Office
Thanks for the reply, So the bending definitely wasn't a concern as I believe they have a laser bending machine.
Message 8 of 12
CWC_Drawing_Office
It will definitely have to be 4 pieces of your first illustration. With miter connections, I want the faces to be matching what it would look like after laser cutting which like you mentioned would be perpendicular to the sheet face.
Message 9 of 12
CWC_Drawing_Office
How would I do it better? I didn't see a miter command, suggestions?
Message 10 of 12
CWC_Drawing_Office
Hi Johnson,
Thank you for the reply, I have had a look at your model and if I'm being honest I'm not too sure I can do the workflow consistently without a bit more know how and practice.
Could you possibly suggest another workflow that might work?
Message 11 of 12
SharkDesign
You can't mitre a sheet of metal unless you can somehow angle the laser head.
Having a flat face to the edge of the sheet is not an issue for welding, they need something to fill anyway.
Is there a problem with the way I did it?
part attached.
Message 12 of 12
CWC_Drawing_Office
Thank you very much for your input. I will definitely keep your workflow in mind.
I have ended up changing the whole design and done it what I believe to be an easier way to manufacture.
Thank you to everyone for the input!
