Sheet Metal Loft Example...
bibleje
bibleje
Attached is a finished part I'd like to make in sheet metal.  I need to be able to manufacture it.  I need to be able to show a flat pattern.  It can be assembled using multiple parts.  I have be told it can be done in 2 parts and using 2 each in an assembly.  The hole needs to be 8.625 dia (for an 8" schedule 10 SS pipe) The more simple the better.  The material is 12ga SS (.109 by my chart anyway).  I welcome any and all help in showing me the proper way to do this process.  Thank you.
John E. Bible
IV 2020
Accepted solutions (3)
YannickEnrico
My experience from working in a sheet metal workshop using laser and press brake leads me to this attached part. You use two identical ones and weld them.
Alternatively you use rip to open it in one side. That one should be doable on a press brake in one piece because it's so low (0.5 in)
_______________________________________________________________________________________
Intel Core i9-14900KF
64 GB DDR5 6000 MHz
2TB WD_BLACK
RTX A4000
Inventor 2026 Professional
blandb
you could just take what you have and split the part, then just place in a single instance into an assembly and circular pattern. Or, you can edit your existing sketches and just split the sketches and make the other half as "construction" or trim and fix, either way.
Then do the same, place in 1 instance and then circular pattern. Just a thought.
Autodesk Certified Professional
bibleje
...wow, that simple.  Thank you!
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
