Sheet metal help
Sheet metal help
Message 1 of 8
Sheet metal help
We are working on a part, trying to make a strip layout for a die design. I'm trying to figure out how to get the side to ben up so i can get a flat from it. the pink part (2577542x redraw 2) is the part we are working on. The silver part (2577542x 2) is the customer part we got sent. Is there a way to get the sides to bend up like shown (circled in the 3rd picture)?
Replies (7)
Message 2 of 8
That part has metal deformation which Inventor will not flatten.
Will only flatten sheet metal made with conventional machines. press brake etc.
There is software that will give you a flat pattern but do not know the names
Message 3 of 8
So I won't be able to do both sides like show? I'm not worried other stuff.
Message 4 of 8
Cannot open your part, I am on 2019 though
Message 5 of 8
CadManagerMoffatNZ
Hi I have attached a part that uses the contour roll command which i think is the command you are after.
Did you find this reply helpful ? If so please use the Accept as Solution or LIKES button below.
Daren
Dell Precision 7720 + P3418HW
Windows 10
Product Design & Manufacturing Collection
Inventor 2021.0.1, Vault Professional 2021, Showcase 2017
Message 6 of 8
Well this flat out when making a flat?
Message 7 of 8
CadManagerMoffatNZ
Hi
the part i attached contained a flat pattern.
So yes contour rolls will flatten.
Daren
Windows 10
Message 8 of 8
Awesome. Thank you. I will have to try it out when I get a chance.
